Unofficial File parts/u9226a.dat
0 ~Train Track 12V Tapered Point Vertical Axle Manual
0 Name: u9226a.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\u9226s01.dat
1 16 0 16 0 12 0 0 0 9 0 0 0 12 4-4cylo.dat
Needs 1 More Vote (CN)
Has uncertified subfiles
| User | Vote |
| RainbowDolphin | Certify |
2023-10-05 23:00:19
The origin has changed. This will break official part using it.
2023-10-06 21:48:17
no, I also changed the parent part...
(there were some other changes too)
You can't change the origin of official parts in the 'parts' directory.
This part is used in many official assemblies. You may have adapted one of them, but the others are broken.
2023-10-07 07:14:12
yes I know but it is here to check if it is ok, then I will do the other 7 assemblies too...
(there are 3 versions each: left/right, straight/branching and manual/electric)
but why is the link to 9609 in 9232 broken?
2023-10-07 13:07:25
Lot doesn't matter if you change the assemblies. You can't change the origin of parts in the parts folder. We cannot guarantee that someone hasn't used this part in a model and changing the origin breaks backward compatibility.
the origin of official part files never must be changed.
it will immediately break user's models.
2024-02-24 13:14:06
looked at my parts again: there are at least two different versions...
one for the manual versions, with a 8 tooth gear (one is always missing)
one with an additional 23T gear (same modulus) above it for the electric versions
(I have 3D printed replacements because some of them are broken)
can the origin get changed if we obsolete the old one? where should it be?
just make 2 new u.... files with the implementations
with the toothgears. it is that simple.
they can or can not use this file.
do NOT change the origin of this one, as it has been official already.
the origin in NEW files can be chosen freely as appropriate
until they become official.
from then on it is FIXED FOREVER.
2024-02-24 21:45:28
ok can this part then please be renumbered to u9226a?
2024-02-27 15:44:04
"parts/u9226.dat" to "parts/u9226a.dat"
Part moved.
Hold reason is now to ensure all official parts are updated to use the corrected part.
2024-03-02 15:13:15
2024-05-31 15:25:45
This part is copyright ©
Rene Rechthaler
Licensed under
CC BY 4.0
