Unofficial File parts/6826.dat
Brick 2 x 2 with Rounded Bottom
0 Brick 2 x 2 with Rounded Bottom
0 Name: 6826.dat
0 !CATEGORY Brick
1 16 0 4 10 0 0 -1 0 -5 0 1 0 0 stud3.dat
1 16 0 24 10 0 0 -16 0 -20 0 6 0 0 box5.dat
1 16 0 4 14 0 0 -1 0 16 0 -1 0 0 boxjcyl4.dat
1 16 0 4 6 0 0 -1 0 16 0 1 0 0 boxjcyl4.dat
1 16 0 4 5 0 0 -1 0 16 0 1 0 0 box3u5p.dat
1 16 0 4 15 0 0 -1 0 16 0 -1 0 0 box3u5p.dat
4 16 20 24 0 16 24 4 16 24 16 20 24 20
4 16 -20 24 20 -16 24 16 -16 24 4 -20 24 0
2 24 20 24 20 20 24 0
2 24 -20 24 0 -20 24 20
0 // Outside
4 16 -4 24 0 -16 24 4 16 24 4 4 24 0
1 16 4 4 0 0 -8 0 0 0 20 -20 0 0 48\1-4cyli.dat
4 16 -4 4 -20 4 4 -20 20 0 -20 -20 0 -20
4 16 16 24 16 -16 24 16 -20 24 20 20 24 20
0 // Inside
1 16 -17 4 0 0 34 0 0 0 17 -17 0 0 1-8cyli.dat
1 16 0 0 20 0 0 -1 0 1 0 1 0 0 s\5174s02.dat
1 16 0 0 20 0 0 1 0 1 0 1 0 0 s\5174s02.dat
4 16 20 0 -20 8.5 0 -17 -8.5 0 -17 -20 0 -20
4 16 -8.5 0 -17 8.5 0 -17 8.5 4 -17 -8.5 4 -17
2 24 -8.5 0 -17 8.5 0 -17
4 16 4.4018 16.0207 -12.0207 2.3727 17.3712 -10 -2.3727 17.3712 -10 -4.4018 16.0207 -12.0207
4 16 .2312 19.8161 -5.9535 -.2312 19.8161 -5.9535 -2.3727 17.3712 -10 2.3727 17.3712 -10
4 16 -.2312 19.8161 -5.9535 .2312 19.8161 -5.9535 1.8238 20.6373 -1.8238 -1.8238 20.6373 -1.8238
4 16 1.8238 20.6373 -1.8238 3.7814 21 0 -3.7814 21 0 -1.8238 20.6373 -1.8238
4 16 8.5 19.5877 0 8.5 0 0 -8.5 0 0 -8.5 19.5877 0
4 16 8.5 19.5877 0 -8.5 19.5877 0 -5.8578 20.0238 0 5.8578 20.0238 0
4 16 3.7814 21 0 5.8578 20.0238 0 -5.8578 20.0238 0 -3.7814 21 0
2 24 -3.7814 21 0 3.7814 21 0
2 24 -8.5 0 0 8.5 0 0
2 24 -20 0 20 20 0 20
5 24 2.3727 17.3712 -10 -2.3727 17.3712 -10 -4.4018 16.0207 -12.0207 .2312 19.8161 -5.9535
5 24 -.2312 19.8161 -5.9535 .2312 19.8161 -5.9535 1.8238 20.6373 -1.8238 -2.3727 17.3712 -10
0 // Top
3 16 -20 0 -20 -17 0 0 -20 0 20
3 16 -20 0 20 -17 0 0 -11.5 0 0
3 16 -11.5 0 0 -8.5 0 0 -20 0 20
4 16 20 0 20 -20 0 20 -8.5 0 0 8.5 0 0
3 16 20 0 20 8.5 0 0 11.5 0 0
3 16 17 0 0 20 0 20 11.5 0 0
3 16 20 0 20 17 0 0 20 0 -20
1 16 0 0 10 0 0 -1 0 1 0 1 0 0 stug-2x1.dat
1 16 0 0 0 0 0 -20 0 1 0 20 0 0 recte4.dat
1 16 10 0 -10 0 0 -1 0 1 0 1 0 0 stud2a.dat
1 16 -10 0 -10 0 0 -1 0 1 0 1 0 0 stud2a.dat
0 // Outside
1 16 -20 4 0 0 1 0 0 0 20 -20 0 0 48\1-4chrd.dat
4 16 -20 0 20 -20 24 20 -20 24 0 -20 4 -20
3 16 -20 0 20 -20 4 -20 -20 0 -20
1 16 20 4 0 0 -1 0 0 0 20 -20 0 0 48\1-4chrd.dat
4 16 20 24 0 20 24 20 20 0 20 20 4 -20
3 16 20 4 -20 20 0 20 20 0 -20
1 16 0 12 20 20 0 0 0 0 12 0 -1 0 rect3.dat
Not releaseable Errors Found (HN) Errors Found (HN)
Hold
Rene Rechthaler [Blechtaler]
Gerald Lasser [GeraldLasser]
2025-01-04 22:17:36
made the following comment.
2025-01-04 22:20:24
This is currently oriented along 5174
or should it follow 1750?
https://library.ldraw.org/parts/1160
2025-01-04 22:38:15
yes I think it should be rotated, also matches the other slopes and curved bricks then...
Philippe Hurbain [Philo]
2025-01-05 07:40:30
1750 orientation for me!
posted a vote of Hold
2025-01-05 16:21:42
Duplicated surfaces at the botton pin.
2025-01-23 09:48:55
changed orientation
be aware that this underside is different from 1750 as it has stud cut outs
Duplicate surfaces removed
2025-04-10 16:22:50
outside curvature should be standard res like 1750
2025-04-22 11:26:00
@Rene, contrary to 1750, whihc works well with Prim-Substitution, this does not.
It has stud cut outs, this will not work good when primitve substitution is applied. Furthermore radius is large at 20 LDU
