Unofficial File parts/911.dat
View official version of part
~Moved to 911a
0 ~Moved to 911a 0 Name: 911.dat 0 Author: Magnus Forsberg [MagFors] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // Baseplate 10 x 48 Train-Ferry Set 343 1 16 0 0 120 1 0 0 0 1 0 0 0 1 911a.dat
Not releaseable Needs More Votes (F) Needs More Votes (F)
None
None
Rene Rechthaler [Blechtaler]
2025-01-06 21:30:54
obsleted and with link to the new one (the origin is outside)
made the following comment.
2025-01-06 22:14:24
This needs to be a Move to-file.
Need help?
2025-01-06 22:26:55
whats the difference?
(you can do whatever you want, you have more knowledge here)
2025-01-06 22:46:01
2025-01-07 17:50:33
why did you delete the history? I wanted to keep the original Author...
(not that it matters much, its just a redirect now)
2025-01-07 18:34:30
Some of the SW we use can replace an old partnumber in a model, using the code in Moved to-files.
They are searching for the wording "~Moved to". That's why we need to make them.
The history is kept in the renumbered file, and should be removed from the Moved to-file.
You made a complete rewrite, and are now the author of the file.
LDraw.org Parts Tracker,
