Unofficial File parts/17979p01.dat
Flag  5 x  6 Hexagonal with Thick C-Clip with Blacktron I Logo Pattern
0 Flag  5 x  6 Hexagonal with Thick C-Clip with Blacktron I Logo Pattern
0 Name: 17979p01.dat
0 !CATEGORY Flag
0 !KEYWORDS Blacktron Renegade, BrickLink x1435pb041, Rebrickable 17979pr0002
0 !KEYWORDS Set 10355
0 // Basepart-Basepart
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\17979s01.dat
0 // Pattern (Backside)
4 16 -2.25 0 30 -2.25 40 110 -2.25 80 110 -2.25 120 30
3 16 -2.25 20 10.175 -2.25 0 30 -2.25 27.75 10.175
3 16 -2.25 27.75 10.175 -2.25 0 30 -2.25 29.25 10.175
3 16 -2.25 29.25 10.175 -2.25 0 30 -2.25 90.75 10.175
3 16 -2.25 90.75 10.175 -2.25 0 30 -2.25 120 30
3 16 -2.25 90.75 10.175 -2.25 120 30 -2.25 92.25 10.175
3 16 -2.25 92.25 10.175 -2.25 120 30 -2.25 100 10.175
0 // Pattern (Frontside)
3 14 2.25 21.5 25 2.25 60 25 2.25 40.75 62.5
3 14 2.25 60 25 2.25 98.5 25 2.25 79.25 62.5
3 14 2.25 40.75 62.5 2.25 79.25 62.5 2.25 60 100
3 16 2.25 40.75 62.5 2.25 60 25 2.25 79.25 62.5
3 16 2.25 0 30 2.25 20 10 2.25 21.5 25
4 16 2.25 79.25 62.5 2.25 98.5 25 2.25 120 30 2.25 80 110
3 16 2.25 60 100 2.25 79.25 62.5 2.25 80 110
3 16 2.25 40 110 2.25 60 100 2.25 80 110
4 16 2.25 40.75 62.5 2.25 60 100 2.25 40 110 2.25 0 30
3 16 2.25 0 30 2.25 21.5 25 2.25 40.75 62.5
3 16 2.25 21.5 25 2.25 20 10 2.25 27.75 10.175
3 16 2.25 21.5 25 2.25 27.75 10.175 2.25 29.25 10.175
3 16 2.25 100 10.175 2.25 120 30 2.25 98.5 25
3 16 2.25 100 10.175 2.25 98.5 25 2.25 92.25 10.175
3 16 2.25 92.25 10.175 2.25 98.5 25 2.25 90.75 10.175
3 16 2.25 90.75 10.175 2.25 98.5 25 2.25 60 25
3 16 2.25 90.75 10.175 2.25 60 25 2.25 29.25 10.175
3 16 2.25 29.25 10.175 2.25 60 25 2.25 21.5 25
Not releaseable Awaiting Admin Review (CCN) Awaiting Admin Review (CCN)
Certify
Rene Rechthaler [Blechtaler]
Certify
Part Reviewer
2025-01-26 19:07:58
edited the part header.
2025-01-26 19:13:29
Header Edits
keywords:
Blacktron I, Blacktron Renegade, Bricklink x1435bp041, Brickowl 559318, Set 10355
to
description:
Flag 5 x 6 Hexagonal with Blacktron Logo I Pattern
to
Flag 5 x 6 Hexagonal with Blacktron I Logo Pattern
made the following comment.
2025-01-26 19:14:58
Header Edits:
*Name changed from "Blacktron Logo I" to "Blacktron I Logo" to better match existing parts.
*Removed Keyword, since it's already in the name
2025-01-26 19:23:05
Whilst not strictly necessary for a such a simple pattern, I think sub-filing this part (base without front and back surface) would be a good idea.
There exists at least one other printed version of it (x1435pb032) and it may get more prints in the future.
Gerald Lasser [GeraldLasser]
posted a vote of Hold
2025-02-07 15:36:38
I agree with chris,
There needs to be a common subfile without printed faces.
From there the other can spawn..
- plain
- prints
Please move rhte unprinted surfaces/geometry to a s\51000s01 file
thansk!
Part Reviewer
2025-02-08 20:02:09
Subfiled.
2025-02-09 21:06:39
Need to put this on hold briefly for clarification:
According to RB this is a version of 17979
https://library.ldraw.org/parts/1168
BL does not distinguish them...
Opinions?
2025-02-09 21:12:11
https://img.bricklink.com/ItemImage/PN/11/x1435pb041.png
shows the big clips from 17979
but the part number (hard to read) is neither 17979 or 51000
2025-02-09 21:13:21
looks like 53913
(BL has this as alternate number)
2025-02-09 21:28:56
There are 3 versions of the base part:
51000: From 2005-2014
17979: From 2014-2019
53913: From 2019-Now (?) (75401 uses this in White, released 2025)
So likely this print only exists for the latest version (53913). I don't know much about the differences though.
2025-02-09 21:29:58
Admittedly though this is highly unlikely to be a print of 51000.
Since 51000 is discontinued and never had any prints, this should be renamed I guess?
2025-02-09 21:53:31
You need to do the same subfiling again, but on 17979 this time.
The differens is in the design of the clips. 51000 has thin clips.
All the new numbers have a thick C-clip, like 17979 have.
btw.
Are there any printed 51000, or is that subfile unnecessary?
2025-02-09 22:07:04
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x1435pb032&name=Flag%205%20x%206%20Hexagonal%20with%20White%20Ice%20Crystal%20Pattern#T=C&C=51
looks like this is the only other print (also on 17979 or 53913)
17979 and 53913 seem to be identical (Alias?)
looks like no prints on 51000, Chris is right, could be renamed, but he could just make a new subfile out of 17979
2025-02-09 22:22:18
So,
Rename this to 17979p01 and the subfile to 17979s01, but change the clips.
Delete recent version of 51000.
Upload a new version of 17979, using the subfile 17979s01.
I can do the renumering.
2025-02-10 07:48:24
@Magnus, the clips od 17979 are a bit more detailed, so I prefer to see a 17979s01 drafted from the original 17979
2025-02-10 11:19:43
thats the question how to proceed:
delete and upload the new ones or renumber and change
anyways, we also need an alias from 17979 to 53913
2025-02-10 17:25:53
Yes, we should subfile the content from 17979.
But if this print is only made on 53913 maybe this should be 53913p01 instead?
Do we know the used partnumber of the other print? BL x1435pb032
If 17979 is never printed, like 51000, then why should we make a subfile 17979s01, and then use it in 53913p01?
2025-02-10 18:16:21
the alias could be the other way around too...
so that 17979 is the alias of 53913
renamed the part.
2025-02-11 22:04:18
"parts/51000p01.dat" to "parts/17979p01.dat"
2025-02-11 22:11:14
Header Edits
description:
to
Comment:
Added clip description.
Part Reviewer
2025-02-23 20:24:33
Thanks for all your comments and help around the part for the Blacktron Renegade. Have moved the design to 17979. Hopfully it is correct/better now.
posted a vote of Certify
2025-04-17 11:17:07
2025-04-17 11:57:03
