Unofficial File parts/u9193.dat
0 Tyre 7/ 50 x 36 with Flat Tread
0 Name: u9193.dat
0 !CATEGORY Tyre
0 !KEYWORDS 43.2, classic
0 !CMDLINE -c375
0 // Nomenclature: width_(mm)/profile_as_%age_of_width x rim_diameter_(mm)
1 16 0 0 -9 54 0 0 0 0 54 0 18 0 48\4-4cylo.dat
1 16 0 0 -9 5.5 0 0 0 0 5.5 0 1 0 48\4-4ring8.dat
1 16 0 0 -9 4.5 0 0 0 0 4.5 0 1 0 48\4-4ring11.dat
1 16 0 0 9 5.5 0 0 0 0 5.5 0 -1 0 48\4-4ring8.dat
1 16 0 0 9 4.5 0 0 0 0 4.5 0 -1 0 48\4-4ring11.dat
1 16 0 0 9 47 0 0 0 0 47 0 1 0 48\4-4edge.dat
1 16 0 0 -9 47 0 0 0 0 47 0 1 0 48\4-4edge.dat
1 16 0 0 9 49 0 0 0 0 49 0 1 0 48\4-4edge.dat
1 16 0 0 -9 49 0 0 0 0 49 0 1 0 48\4-4edge.dat
1 16 0 0 9 51 0 0 0 0 51 0 1 0 48\4-4edge.dat
1 16 0 0 -9 51 0 0 0 0 51 0 1 0 48\4-4edge.dat
1 16 0 0 -6 42 0 0 0 0 42 0 12 0 48\4-4cylo.dat
1 16 0 0 7 2 0 0 0 0 2 0 -1 0 48\4-4con21.dat
1 16 0 0 -7 2 0 0 0 0 2 0 1 0 48\4-4con21.dat
1 16 0 0 7 44 0 0 0 0 44 0 2 0 48\4-4cylo.dat
1 16 0 0 -7 44 0 0 0 0 44 0 -2 0 48\4-4cylo.dat
Errors Found (HHN)
Gerald Lasser [GeraldLasser]
Rene Rechthaler [Blechtaler]
2025-03-05 20:30:04
differentiated and fixed the two variants of 36.dat
edited the part header.
2025-03-19 21:47:48
Header Edits
keywords:
classic
to
classic, 43.2
added diameter
posted a vote of Hold
2025-03-20 12:34:13
If this is reworked, then I would prefer to have the sidewall relief modeled and not only as (invisible) edgelines.
Could be doen with some cones IMHO
made the following comment.
2025-03-20 12:42:02
Obsolete 36.dat, or make Moved to-files?
2025-03-20 20:34:57
ripples would be possible (needs lots of new cones), but unnecessary (too small)
idk if obsolete or moved-to, its a part split into variants
2025-03-21 15:30:39
Updating without a suggested plan for the official plan is not good.
We need to handle the old 36.dat. Obsolete it, or make a Moved to-file?
Since there is a change in the outer diameter we need to obsolete the old file.
Please upload an obsoleted 36.dat
Jeff Jones [notmaster]
2025-03-21 15:48:47
moved to
2025-03-21 16:34:45
cones or cylo+ring like 3139b?
https://library.ldraw.org/parts/37251
geometrically ideal would be a mixed-mode torus, but that would be overkill on poly count...
2025-03-21 17:00:31
i am not sure if the 36.dat is really wrong...
the air / foam tyres are smaller than the solid rubber ones.
the 36.dat fits quite well for the black air tyres, this u9193 is the grey latex rubber and the u9194 is the solid black rubber.
counts more like "variants"
