Unofficial File parts/30842.dat
Car Base  4 x 14 x  1 with Tow Ball Socket
0 Car Base 4 x 14 x 1 with Tow Ball Socket 0 Name: 30842.dat 0 Author: Massimo Maso [Sirio] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2018-01-28 {LEGO Digital Designer} Original part shape 0 !HISTORY 2025-05-04 [Sirio] File preparation for LDraw Parts Tracker
0 // Subparts 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\30842s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\30842s01.dat 0 // Primitives 1 16 0 -9 90 2.5 0 0 0 -1 0 0 0 6 rect.dat 1 16 0 0 120 0 0 -1 0 1 0 1 0 0 stug-2x2.dat 1 16 -10 0 30 0 0 -1 0 1 0 1 0 0 stug-1x5.dat 1 16 10 0 30 0 0 -1 0 1 0 1 0 0 stug-1x5.dat 1 16 -30 0 -50 0 0 -1 0 1 0 1 0 0 stug-1x3.dat 1 16 -10 0 -50 0 0 -1 0 1 0 1 0 0 stug-1x3.dat 1 16 10 0 -50 0 0 -1 0 1 0 1 0 0 stug-1x3.dat 1 16 30 0 -50 0 0 -1 0 1 0 1 0 0 stug-1x3.dat 1 16 -10 0 -110 0 0 -1 0 1 0 1 0 0 stug-1x3.dat 1 16 10 0 -110 0 0 -1 0 1 0 1 0 0 stug-1x3.dat 1 16 0 0 30 20 0 0 0 1 0 0 0 50 rect3.dat 1 16 0 4 120 20 0 0 0 -4 0 0 0 20 box2-7.dat 1 16 0 4 -110 20 0 0 0 -4 0 0 0 -30 box2-7.dat 1 16 0 4 120 1 0 0 0 -5 0 0 0 1 stud4.dat 1 16 0 4 60 1 0 0 0 -5 0 0 0 1 stud4a.dat 1 16 0 4 40 1 0 0 0 -5 0 0 0 1 stud4.dat 1 16 0 4 20 1 0 0 0 -5 0 0 0 1 stud4a.dat 1 16 0 4 0 1 0 0 0 -5 0 0 0 1 stud4.dat 1 16 0 4 -20 1 0 0 0 -5 0 0 0 1 stud4a.dat 1 16 0 4 -40 1 0 0 0 -5 0 0 0 1 stud4.dat 1 16 0 4 -60 1 0 0 0 -5 0 0 0 1 stud4a.dat 1 16 0 4 -80 1 0 0 0 -5 0 0 0 1 stud4.dat 1 16 0 4 -100 1 0 0 0 -5 0 0 0 1 stud4a.dat 1 16 0 4 60 6 0 0 0 1 0 0 0 6 4-4edge.dat 1 16 0 4 20 6 0 0 0 1 0 0 0 6 4-4edge.dat 1 16 0 4 -20 6 0 0 0 1 0 0 0 6 4-4edge.dat 1 16 0 4 -60 6 0 0 0 1 0 0 0 6 4-4edge.dat 1 16 0 4 -100 6 0 0 0 1 0 0 0 6 4-4edge.dat 1 16 0 4 -120 1 0 0 0 -5 0 0 0 1 stud4.dat 1 16 -40 10 -50 0 1 0 1 0 0 0 0 -1 stug2-3x1.dat 1 16 40 10 -50 0 -1 0 1 0 0 0 0 1 stug2-3x1.dat 0 BFC INVERTNEXT 1 16 0 14 98.5 17 0 0 0 0 -10 0 2.5 0 box2-5.dat 0 BFC INVERTNEXT 1 16 0 14 81.5 17 0 0 0 0 -10 0 -2.5 0 box2-5.dat 0 BFC INVERTNEXT 1 16 0 24 120 16 0 0 0 -20 0 0 0 16 box5.dat 1 16 0 -10 90 10 0 0 0 2 0 0 0 10 box4o8a.dat 1 16 0 -20 90 0 -1 0 0 0 1 -1 0 0 joint8socket2.dat 0 // Faces 4 16 -20 0 -20 -20 0 -80 20 0 -80 20 0 -20 4 16 -20 24 -140 -16 24 -136 16 24 -136 20 24 -140 4 16 -20 8 -140 -20 24 -140 20 24 -140 20 8 -140 4 16 -20 0 100 -10 -8 100 10 -8 100 20 0 100 4 16 -20 24 140 -20 8 140 20 8 140 20 24 140 4 16 20 24 140 16 24 136 -16 24 136 -20 24 140 4 16 -20 0 80 20 0 80 10 -8 80 -10 -8 80 4 16 16 4 76 -16 4 76 -16 24 76 16 24 76 4 16 -16 24 76 -17 24 79 17 24 79 16 24 76 4 16 16 24 104 17 24 101 -17 24 101 -16 24 104 4 16 6 -4 96 2.5 -9 96 -2.5 -9 96 -6 -4 96 4 16 6 -4 84 -6 -4 84 -2.5 -9 84 2.5 -9 84 4 16 17 4 96 6 -4 96 -6 -4 96 -17 4 96 4 16 17 4 84 -17 4 84 -6 -4 84 6 -4 84 4 16 16 4 -99 -16 4 -99 -16 4 -76 16 4 -76 4 16 16 4 -71 16 4 -76 -16 4 -76 -16 4 -71 4 16 -16 4 -71 -16 4 -69 16 4 -69 16 4 -71 4 16 16 4 -69 -16 4 -69 -16 4 -51 16 4 -51 4 16 16 4 -49 16 4 -51 -16 4 -51 -16 4 -49 4 16 -16 4 -49 -16 4 -31 16 4 -31 16 4 -49 4 16 16 4 -29 16 4 -31 -16 4 -31 -16 4 -29 4 16 -16 4 -29 -16 4 -24 16 4 -24 16 4 -29 4 16 16 4 -21 16 4 -24 -16 4 -24 -16 4 -21 4 16 8 4 -101 -8 4 -101 -8 4 -99 8 4 -99 4 16 8 4 -21 -8 4 -21 -8 4 -19 8 4 -19 4 16 16 24 -136 -16 24 -136 -16 4 -136 16 4 -136 4 16 16 4 -101 16 4 -136 -16 4 -136 -16 4 -101 4 16 16 4 -19 -16 4 -19 -16 4 76 16 4 76 0 // Edges 2 24 20 0 100 -20 0 100 2 24 16 4 76 -16 4 76 2 24 16 4 -136 -16 4 -136 2 24 20 24 140 -20 24 140 2 24 16 24 76 -16 24 76 2 24 16 24 -136 -16 24 -136 2 24 20 24 -140 -20 24 -140
User Vote
MagFors Certify
2025-05-09 20:40:22
Rene Rechthaler [Blechtaler]
posted a vote of Hold.
2025-05-09 21:11:12
overlaps at the bottom studs
2025-05-10 21:57:48
Rather than there was an overlap in bottom studs, some edge lines were missing.
Now I have added them and it should be corrected.
2025-05-10 22:04:37
nope still overlap (go to random color mode)
made the following comment.
2025-05-11 08:12:05
these
1 16 0 18 60 1 0 0 0 -1.5 0 0 0 1 stud4a.dat
1 16 0 18 20 1 0 0 0 -1.5 0 0 0 1 stud4a.dat
1 16 0 18 -20 1 0 0 0 -1.5 0 0 0 1 stud4a.dat
1 16 0 18 -60 1 0 0 0 -1.5 0 0 0 1 stud4a.dat
1 16 0 18 -100 1 0 0 0 -1.5 0 0 0 1 stud4a.dat
can definitely get deleted.
the rest of them should be all stud4 (not stud4a)
->if there is a small edge inside, it isnt that bad...
2025-05-11 08:32:18
You're right. Fixed now.
2025-10-03 16:53:17
The primitive Joint8socket2 has been heavily modified to make it usable in both parts.
2025-10-03 17:42:21
joint8socket2 is a primitive, not a subpart.
2025-10-09 16:54:45
2025-10-09 21:49:36
Too wide, overlapping
4 16 -23 24 -140 -16 24 -136 16 24 -136 23 24 -140
4 16 -20 8 -140 -23 24 -140 23 24 -140 20 8 -140
2 24 23 24 -140 -23 24 -140
2025-10-13 23:12:14
posted a vote of Certify.
2025-10-14 18:35:55
