Unofficial File parts/3068bp1c.dat
0 Tile 2 x 2 with White Viking Skull Pattern
0 Name: 3068bp1c.dat
0 Author: Peter Grass [Evilspyre]
0 !CATEGORY Tile
0 !KEYWORDS Bricklink 3068pb2679, Brickowl 169451, Brickset 114234
0 !KEYWORDS How To Train Your Dragon, Rebrickable 3068bpr9311, Set 10375
0 !KEYWORDS Toothless
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bs01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp1cs01.dat
1 16 0 0 0 0 0 -1 0 1 0 -1 0 0 s\3068bp1cs01.dat
Needs 2 More Votes (N)
Has Uncertified Subfiles
2026-01-26 10:55:50
2026-01-26 10:59:33
posted a vote of Hold
2026-01-26 11:39:15
made the following comment.
2026-01-26 16:04:52
Why is this a Viking? I see nothing related to a viking here.
Only a skull, with tusks.
2026-01-26 16:32:45
In the movies etc its the hairy hooligan tribe of vikings and that is their tribal insignia.
2026-01-27 14:40:39
It should be properly diagonally alligned now, and of course the correct dimensions.
2026-01-27 14:58:16
2026-01-27 14:59:45
Well OK not quite, moved some parts from the subpart to the main file since those were tricky to get right.
Rene Rechthaler [Blechtaler]
2026-01-27 16:26:08
12.41 0 -12.42 is the only vertex not at 45° (x=-z)
if you equalize it, everything could get moved back to the subfile again
2026-01-28 12:28:50
Samll gap on the lower right side near:
3 16 20.21 0 -20.21 12.62 0 -12.63 11.14 0 -13.96
(Some of the lower points from the sup-pattern do not lie on a diagonal.)
