Unofficial File parts/7813.dat
Brick  4 x  5 with Rounded Plate End,  2 x  2 Recess, Axlehole and Pin Holes
0 Brick  4 x  5 with Rounded Plate End,  2 x  2 Recess, Axlehole and Pin Holes
0 Name: 7813.dat
0 !CATEGORY Brick
0 !KEYWORDS Brickowl 1395469
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\7813s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\7813s01.dat
0 // round plate end
1 16 0 22 56 4 0 0 0 0 2 0 1 0 rect2p.dat
1 16 0 20 20 36 0 0 0 -1 0 0 0 -4 rect3.dat
3 16 4 24 56 -4 24 56 0 24 60
4 16 -4 20 56 4 20 56 36 20 24 -36 20 24
3 16 40 16 20 0 16 60 -40 16 20
0 // center cutout
1 16 0 8 0 6 0 0 0 1 0 0 0 6 4-4ndis.dat
1 16 0 8 0 6 0 0 0 1 0 0 0 6 4-4edge.dat
1 16 0 8 0 6 0 0 0 4 0 0 0 6 4-4cyli.dat
1 16 0 12 0 1 0 0 0 -3 0 0 0 1 stud4a.dat
1 16 0 12 0 8 0 0 0 1 0 0 0 8 4-4edge.dat
1 16 0 12 0 8 0 0 0 -1 0 0 0 8 4-4ndis.dat
2 24 40 16 20 -40 16 20
4 16 -20 8 20 20 8 20 40 16 20 -40 16 20
2 24 20 8 20 -20 8 20
3 16 20 8 20 -20 8 20 0 8 6
3 16 4 8 -20 0 8 -6 -4 8 -20
3 16 0 12 -8 5.6023 12 -18 -5.6023 12 -18
2 24 4 8 -20 -4 8 -20
4 16 26.7641 12 16 -26.7641 12 16 -36 20 16 36 20 16
2 24 26.7641 12 16 -26.7641 12 16
3 16 -26.7641 12 16 26.7641 12 16 0 12 8
0 // front technic brick
1 16 0 10 -40 6 0 0 0 0 6 0 1 0 4-4ndis.dat
1 16 0 10 -40 1 0 0 0 0 1 0 20 0 axlehol4.dat
1 16 0 14 -18 5.6023 0 0 0 0 2 0 -1 0 rect.dat
2 24 2 16 -20 -2 16 -20
4 16 5.6023 16 -18 2 16 -20 -2 16 -20 -5.6023 16 -18
4 16 -2 16 -20 2 16 -20 2 14 -20 -2 14 -20
4 16 -2.5 12.5 -20 -2 14 -20 2 14 -20 2.5 12.5 -20
4 16 -2.5 12.5 -20 2.5 12.5 -20 4 8 -20 -4 8 -20
2 24 -2 24 -36 2 24 -36
3 16 -2 24 -36 0 16 -36 2 24 -36
3 16 -2 24 -36 2 24 -36 0 24 -40
5 24 0 16 -40 0 16 -36 2 15.6023 -40 -2 15.6023 -40
0 // studs
1 16 0 0 -30 0 0 -1 0 1 0 1 0 0 stug2-4x1.dat
1 16 -30 0 0 0 0 -1 0 1 0 1 0 0 stug-1x2.dat
1 16 30 0 0 0 0 -1 0 1 0 1 0 0 stug-1x2.dat
1 16 0 8 0 0 0 -1 0 1 0 1 0 0 stug-2x2.dat
1 16 0 16 30 0 0 -1 0 1 0 1 0 0 stug-4x1.dat
1 16 0 16 50 0 0 -1 0 1 0 1 0 0 stug-2x1.dat
0 // bottom antistuds
1 16 0 20 40 1 0 0 0 -1 0 0 0 1 stug4-1x3.dat
1 16 0 20 20 1 0 0 0 -1 0 0 0 1 stud4a.dat
Rene Rechthaler [Blechtaler]
2026-03-11 11:58:16
origin correct? (centered on the vertical hole)
orientation correct? (pin/axlehole to front)
Philippe Hurbain [Philo]
made the following comment.
2026-03-11 12:38:31
Origin is fine, I'd say rotate it 180° as the understandability of part seen from default orientation (no occlusion from higher elements in front of lower ones), moreover half circle parts are oriented with circle in front.
2026-03-11 12:39:14
...(seen from default orientation) would be better
2026-03-11 16:35:11
but if the half circle plate is at the front, you barely see the technic pin/axle holes, and I think these are more important
2026-03-12 12:12:06
I personnally don't think so... Also would match the orientation of this: https://library.ldraw.org/parts/51655
