Unofficial File parts/87544.dat
View official version of part
Panel  1 x  2 x  3 Reinforced
0 Panel 1 x 2 x 3 Reinforced 0 Name: 87544.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Panel 0 !KEYWORDS Brickowl 730588 0 !HISTORY 2010-12-31 [PTadmin] Official Update 2010-03 0 !HISTORY 2020-05-25 [PTadmin] Update description 0 !HISTORY 2020-06-28 [PTadmin] Official Update 2020-01 0 !HISTORY 2026-04-28 [Blechtaler] reworked, original by [Brickaneer]
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\87544s01.dat 0 // outside face 4 16 -20 0 10 20 0 10 20 72 10 -20 72 10
None
2026-04-28 10:36:56
synchronized the reinforced panels (same structure, same top corners)
all have the top studs included in the subpart (seems to be a relic from the old one which had both variants)
made the following comment.
2026-04-28 20:16:50
change isnt big enough to count as rework
edited the part header.
2026-04-28 22:56:45
Header Edits
description:
Panel 1 x 2 x 3 Reinforced with Hollow Studs
to
Comment:
this part (with reinforced sides) has no solid studs variant
2026-04-29 10:43:13
took authorship for license
2026-08-29 15:23:15
Header Edits
preview:
to
Comment:
2026-08-29 15:41:03
I've removed the preview rotation on all the official files too. They should show the difference, un-reinforced/reinforced.
The fact that most have print on the bigger "back" surface is not a good reason to flip the base part.
