Unofficial File parts/122c06.dat
View official version of part
Part Attributes: Base Part: 122.dat
Plate  2 x  2 with White Wheels and Tyres 8/ 75 x 8 Offset Tread
0 Plate 2 x 2 with White Wheels and Tyres 8/ 75 x 8 Offset Tread 0 Name: 122c06.dat 0 Author: Alex Taylor [anathema] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2020-12-29 [PTadmin] Official Update 2020-03 0 !HISTORY 2026-05-29 [Blechtaler] corrected wheel position
1 16 0 0 0 1 0 0 0 1 0 0 0 1 122c02.dat 1 256 -31 6 0 0 0 1 0 1 0 -1 0 0 4084.dat 1 256 31 6 0 0 0 -1 0 1 0 1 0 0 4084.dat
Not releaseable Errors Found (HF) Errors Found (HF)
User Vote
MagFors Hold
Rene Rechthaler [Blechtaler]
2026-05-29 20:22:11
corrected wheel diameter, added rear ridge, corrected wheel position in the shortcuts
posted a vote of Hold
2026-05-29 20:35:52
You can't change the geometry of an official file like this.
This change will brake every model using this part.
made the following comment.
2026-07-19 18:42:39
I will remove these files, based on this re-design.
2026-07-20 11:12:22
even if the tyre gets corrected (either reverted or obsoleted+fixed) the position is wrong
2026-07-20 20:55:08
I guess it's unlikely given the age, but does someone know the official ID for this (this used to be pre-assembled entirely)? Maybe that could be used for the redesigned ones...
This part is copyright © Alex Taylor
LDraw.org Parts Tracker, Rene Rechthaler
