Unofficial File parts/116980.dat
0 Wheel Rim 8 x 11.2 with One Smooth Side and Tyre 6/ 30 x 11 Smooth with Axle Pin Hard Snap
0 Name: 116980.dat
0 !CATEGORY Wheel
0 !KEYWORDS Brickowl 1649771, Rebrickable 6683c01
1 16 0 0 10 0 1 0 0 0 1 1 0 0 5794.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 6683.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 50951.dat
Needs 2 More Votes (N)
Rene Rechthaler [Blechtaler]
2026-06-04 22:21:21
posted a vote of Hold
2026-06-05 14:31:03
IMO the origin should be the same as the pin.
If this is a part/shortcut we need an uncoloured base part, and this would then be -p01.
Do we know if this is a part/assy number, or a designID?
made the following comment.
2026-06-05 19:04:52
hm, when I made it yesterday, it linked to this part: https://rebrickable.com/parts/6683c01/wheel-11-x-8-with-center-groove-one-smooth-side-with-tyre-axle-pin-assembly/
it still lists 116980 as Lego assembly number, but that may also change... (new part, got changed a lot already)
-> this got changed today, which broke the link
-> you are free to renumber
the newE post with new june parts lists this as Element ID: 6600064 Design ID: 116980
-> if we need a fully uncolored base, what number should it have?
for the origin: center of the whole pin or center of axle section? the new 6683c01 RB number suggests the rim as base part (like now, centered and colorable)
Orion Pobursky [OrionP]
2026-06-06 02:29:39
How does this come in the box? Assembled or apart. If assembled, the uncolored version should have this number and the colored version with a pXX suffix.
I agree with Magnus on the origin.
2026-06-06 08:28:00
do we need a wheel sub-assembly of rim+tyre? (as said, i dont know if glued or dual, but it comes as these 3 parts together, and you are not supposed to separate them)
anyone, feel free to renumber it to any number (6683c01, 116980c01 or 116980p01)
2026-06-06 12:01:41
or should I reupload this with a new name? (and change this number to uncolored?)
2026-06-06 14:55:05
I think we need more information before we move forward.
Gerald Lasser [GeraldLasser]
2026-06-11 10:52:58
out of the box it comes pre-assembled
You can disassemble the whole thing, the tire comes off easily, the pin needs to be pushed out. No pulling possible
Jeff Jones [notmaster]
edited the part header.
2026-06-11 10:56:26
Header Edits
description:
Wheel Rim 8 x 11.2 with Curved Side and Black Tyre 6/ 30 x 11 Smooth with Bright Light Blue Axle Pin Hard Snap
to
Wheel Rim 8 x 11.2 with Curved Side and Tyre 6/ 30 x 11 Smooth with Axle Pin Hard Snap
2026-06-11 15:13:32
split into colored/uncolored shortcut
2026-06-11 15:13:32
2026-06-11 15:14:50
2026-06-11 15:18:24
2026-09-06 15:35:27
Header Edits
description:
to
(name/syntax correct?)
