0 Electric Plug (Type 2) Twin Extra-Wide
0 Name: u9607.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\u9607s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\u9607s01.dat
1 16 0 -3.75 1.34 10 0 0 0 -3.75 0 0 0 1.34 box2-9p.dat
1 16 0 0 4.005 0 0 10 0 1 0 1.325 0 0 rect2p.dat
1 16 0 0 6.67 10 0 0 0 -7.5 0 0 0 1.34 box3u8p.dat
1 16 0 0 9.335 0 0 10 0 1 0 1.325 0 0 rect2p.dat
1 16 0 0 12 10 0 0 0 -7.5 0 0 0 1.34 box3u8p.dat
1 16 0 0 14.665 0 0 10 0 1 0 1.325 0 0 rect2p.dat
1 16 0 0 17.33 10 0 0 0 -7.5 0 0 0 1.34 box3u8p.dat
1 16 0 0 19.995 0 0 10 0 1 0 1.325 0 0 rect2p.dat
1 16 0 -3.75 22.66 10 0 0 0 -3.75 0 0 0 -1.34 box2-9p.dat
1 16 0 5.185 1.34 10.571 0 0 0 2.315 0 0 0 1.34 box2-9p.dat
1 16 0 2.87 4.005 0 0 10.571 0 -1 0 1.325 0 0 rect2p.dat
1 16 0 2.87 6.67 10.571 0 0 0 4.63 0 0 0 1.34 box3u8p.dat
1 16 0 2.87 9.335 0 0 10.571 0 -1 0 1.325 0 0 rect2p.dat
1 16 0 2.87 12 10.571 0 0 0 4.63 0 0 0 1.34 box3u8p.dat
1 16 0 2.87 14.665 0 0 10.571 0 -1 0 1.325 0 0 rect2p.dat
1 16 0 2.87 17.33 10.571 0 0 0 4.63 0 0 0 1.34 box3u8p.dat
1 16 0 2.87 19.995 0 0 10.571 0 -1 0 1.325 0 0 rect2p.dat
1 16 0 5.185 22.66 10.571 0 0 0 2.315 0 0 0 -1.34 box2-9p.dat
4 16 -10 -7.5 0 -10.571 7.5 0 10.57 7.5 0 10 -7.5 0
4 16 10 -7.5 24 10.57 7.5 24 -10.571 7.5 24 -10 -7.5 24
Has uncertified subfiles
| User | Vote |
| RainbowDolphin | Certify |
It may look like a Type 3 but it is only used with the Type 1 and 2 plugs (there are versions with Type 1 or 2 Pins).
This is the wide version of these "old" plugs (like 2775 to 766 is this part to 567)
Do we also need the versions with cable stubs? If a cable has mixed ends, how does it get numbered/named?
Suggestion:
Electric Plug (Type 5) Twin Extra-Wide
and the assy shortcuts should contain a cable end, aand use "... with Cable End"
When in doubt, look at the descriptions we are already using.
Hold voting for renumbering.
http://www.peeron.com/inv/parts/x466
or this one:
http://www.peeron.com/inv/parts/x562c
I did not find any number on it.
The Type 3 is very different (splits open).
I'm fine with assigning a u-number (the admins should just renumber and rename).
But u9607 work too.
Is "Type" related to the plug or the pin, in the Electric Plug family?
Type 1 is the hollow pin
Type 2 is the cross cut pin
but,
Type 3 is a plug, similar to u9607, but narrow
Type 4 is a set of plugs, single, twin and twin extra-wide
* Edger add these:
5 24 -20.682 -3.182 14.701 -20.37 -6.929 14.234 -21.196 -2.413 15.469 -20.328 -6.938 14.172
5 24 -14.318 -3.182 19.299 -14.63 -6.929 19.766 -14.672 -6.938 19.828 -13.804 -2.413 18.531
but just in one hole, so something is wrong
* Rects
keywords:
12V, Bricklink bb0093, connector, Peeron x562c
to
what is with the rects? no slanted rects here, no mismatches...
removed keywords (this specific single part isnt inventoried anywhere)
is it ok to remove the keywords completely?
LDraw.org Parts Tracker,
very small gaps due to rounding
