Unofficial File parts/u9608c01.dat
Part Attributes: Base Part: u9608.dat
External site data provided by part keywords View on BrickLink
Electric Plug Triple with Hollow Pin (Type 1) (Complete)
0 Electric Plug Triple with Hollow Pin (Type 1) (Complete) 0 Name: u9608c01.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP place on 833 0 !HELP 1 1 0 0 0 1 0 0 0 1 0 0 0 1 833.dat 0 !HELP 1 1 0 -14 70 -1 0 0 0 -1 0 0 0 1 u9608c01.dat 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 3wayconc
1 16 0 0 0 1 0 0 0 1 0 0 0 1 u9608.dat 1 494 0 6 0 1 0 0 0 1 0 0 0 1 u9238.dat 1 494 10 0 0 1 0 0 0 1 0 0 0 1 u9238.dat 1 494 -10 0 0 1 0 0 0 1 0 0 0 1 u9238.dat 1 494 0 0 17 .98079 0 -.19509 0 1 0 .19509 0 .98079 u9021.dat 1 494 10 -6 17 .98079 0 -.19509 0 1 0 .19509 0 .98079 u9021.dat 1 494 -10 -6 17 .98079 0 -.19509 0 1 0 .19509 0 .98079 u9021.dat
    Line 19: 1 494 0 0 17 .98079 0 -.19509 0 1 0 .19509 0 .98079 u9021.dat
    Line 20: 1 494 10 -6 17 .98079 0 -.19509 0 1 0 .19509 0 .98079 u9021.dat
    Line 21: 1 494 -10 -6 17 .98079 0 -.19509 0 1 0 .19509 0 .98079 u9021.dat
None
2023-09-15 10:14:32
posted a vote of Certify.
2024-05-31 15:28:07
Willy Tschager [Holly-Wood]
posted a vote of Hold.
2024-06-02 12:00:26
* Screws have to be rotated. Currently they overlap.
* Missing edges between screw and pin. Isecalc is your friend:
2 24 -7.921328 -6 15.611076 -7.547973 -6 16.512281
2 24 -7.921265 -6 18.388944 -7.548063 -6 17.487721
2 24 -7.547973 -6 16.512281 -7.548063 -6 17.487721
2 24 -8.611076 -6 19.078672 -9.512281 -6 19.452026
2 24 -8.611076 -6 19.078672 -7.921265 -6 18.388944
2 24 -11.388944 -6 19.078735 -10.487721 -6 19.451937
2 24 -9.512281 -6 19.452026 -10.487721 -6 19.451937
2 24 -12.078672 -6 18.388924 -12.452027 -6 17.487719
2 24 -11.388944 -6 19.078735 -12.078672 -6 18.388924
2 24 -12.451937 -6 16.512279 -12.078735 -6 15.611056
2 24 -12.452027 -6 17.487719 -12.451937 -6 16.512279
2 24 -11.388924 -6 14.921328 -10.487719 -6 14.547974
2 24 -12.078735 -6 15.611056 -11.388924 -6 14.921328
2 24 -8.611055 -6 14.921265 -9.512279 -6 14.548063
2 24 -10.487719 -6 14.547974 -9.512279 -6 14.548063
2 24 -7.921328 -6 15.611076 -8.611055 -6 14.921265
2 24 -13.325878 -7 19.222281 -12.774113 -7 19.774113
2 24 -7.225887 -7 14.225887 -6.674122 -7 14.777719
2 24 -7.778787 -7 13.673566 -7.778787 -7.5 13.673566
2 24 -7.547973 -3.37485 16.512281 -7.921327 -3.624367 15.611076
2 24 -7.548063 -3.37491 17.487721 -7.547973 -3.37485 16.512281
2 24 -7.548063 -3.37491 17.487721 -7.921265 -3.624325 18.388945
2 24 -7.921265 -3.624325 18.388945 -8.373525 -3.926575 18.84115
2 24 -8.373525 -3.926575 15.158825 -7.921327 -3.624367 15.611076
2 24 -8.611076 -3.973812 19.078673 -8.373525 -3.926575 18.84115
2 24 -9.512281 -4.153017 19.452027 -8.611076 -3.973812 19.078673
2 24 -9.512281 -4.153017 19.452027 -10 -4.25 19.451982
2 24 -9.512279 -4.153016 14.548063 -10 -4.25 14.548018
2 24 -8.611055 -3.973808 14.921265 -9.512279 -4.153016 14.548063
2 24 -8.611055 -3.973808 14.921265 -8.373525 -3.926575 15.158825
2 24 -10.487721 -4.153016 19.451937 -10 -4.25 19.451982
2 24 -10.487721 -4.153016 19.451937 -11.388945 -3.973808 19.078735
2 24 -11.626475 -3.926575 18.841175 -11.388945 -3.973808 19.078735
2 24 -11.388924 -3.973812 14.921327 -11.626475 -3.926575 15.15885
2 24 -10.487719 -4.153017 14.547973 -11.388924 -3.973812 14.921327
2 24 -10 -4.25 14.548018 -10.487719 -4.153017 14.547973
2 24 -11.626475 -3.926575 18.841175 -12.078673 -3.624367 18.388924
2 24 -12.452027 -3.37485 17.487719 -12.078673 -3.624367 18.388924
2 24 -12.451937 -3.37491 16.512279 -12.452027 -3.37485 17.487719
2 24 -12.451937 -3.37491 16.512279 -12.078735 -3.624325 15.611055
2 24 -11.626475 -3.926575 15.15885 -12.078735 -3.624325 15.611055
2 24 -12.221213 -7.5 20.326434 -6.674122 -7.5 14.777719
2 24 -12.221213 -7.5 20.326434 -12.221213 -7 20.326434
2 24 -7.778787 -7.5 13.673566 -13.325878 -7.5 19.222281
made the following comment.
2024-06-02 13:11:18
screws are like here: https://library.ldraw.org/official/10252
should the hollow pin get a hole or should I add lines?
2024-06-02 15:20:33
Just rotated the screws by some degree and add the lines. Keep it simple.
2024-06-02 15:28:58
2024-06-02 15:37:51
Thumbs up.
2024-06-02 17:00:46
with a lot of lines (they could be in u9238 but that one is official)
2024-06-02 19:11:53
The edge lines can't be here. They need to be in u9238.
2024-06-02 19:13:18
with hole?
2024-10-23 17:05:35
removed intersection edgelines (fixed in the pin)
2024-10-23 20:28:07
2024-11-14 13:03:26
corrected the vertical height of the central electrical contact (is now 6 LDU)
LDraw.org Parts Tracker,
