Unofficial File parts/u9608c05.dat
Base Part: u9608.dat
View on BrickLink
0 Electric Plug Triple with Cross-Cut Pin (Type 2) and Cable End (Complete)
0 Name: u9608c05.dat
0 !KEYWORDS Bricklink x466ac200, Peeron x466a, Set 708-1
1 16 0 0 0 1 0 0 0 1 0 0 0 1 u9608c02.dat
1 375 0 0 0 -1 0 0 0 1 0 0 0 1 s\u9609s01.dat
Needs 1 More Vote (CN)
Has uncertified subfiles
| User | Vote |
| RainbowDolphin | Certify |
2023-09-15 15:28:56
got the position wrong
I don't mind the compact design using a very short cable, but I would prefer at least one loop of the cable, indicating it being longer IRL.
Shouldn't the length be in the description, instead of added as Help info?
Why doesn't the structure of this cable follow the other examples we already have?
You need to make a set of plugs, including a cable end, and then use those in this complete part.
The short cable stub is allways a Part, while the Cable End is a subpart. Both should use thier own unique partnumber.
2023-10-05 23:05:06
swapped cable/plug coloring
2024-05-31 15:20:40
LDraw.org Parts Tracker,
