Unofficial File parts/32004b.dat
0 Wheel Rim 18 x 41 Model Team Type 2
0 Name: 32004b.dat
0 !KEYWORDS 68.8 x 24S, Brickowl 840849, Racing Truck, Set 5563
0 !HISTORY 2024-07-01 [GeraldLasser] completely rewritten and subfiled for use with b-version, original by [Shimpei-Ohsumi]
0 // Nomenclature: width_(mm) x rim_diameter_(mm) [optional qualifier]
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32004s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32004bs01.dat
1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\32004bs01.dat
1 16 0 0 0 0.5 0.866 0 -0.866 0.5 0 0 0 1 s\32004bs01.dat
1 16 0 0 0 -0.5 0.866 0 -0.866 -0.5 0 0 0 1 s\32004bs01.dat
1 16 0 0 0 -0.5 -0.866 0 0.866 -0.5 0 0 0 1 s\32004bs01.dat
1 16 0 0 0 0.5 -0.866 0 0.866 0.5 0 0 0 1 s\32004bs01.dat
Needs 1 More Vote (CF)
| User | Vote |
| Holly-Wood | Certify |
Uses s/32004bs01-new.dat instead of s/32004bs01.dat
...did not hit save... now correct subfile
Existing certification-votes were deleted.
Why are you taking over the ownership of this file?
I think the original author, Shimpei Ohsumi should remain as the creator of the file.
reinstated original author
sorry he got lost when arranged the new files
2021-04-19 20:35:01
Needs a CC BY 4.0 rewrite
2024-07-01 13:48:27
2024-07-01 13:48:57
cc by 4 rewrite
Rounded
checked my real part, found some errors (cant check the T1, but I have T2)
-axlehole is mirrored (the twoo teeth are the other way)
-rear support from axlehole to pinhole is diagonal
checked the RB pic, error is in the subpart (this one seems correct)
2026-06-09 14:35:19
This part is copyright ©
Gerald Lasser
Licensed under
CC BY 4.0
