Unofficial File parts/u9448.dat
~Magnet Cylindrical Casing for Train Base  6 x 22 Type 1
0 ~Magnet Cylindrical Casing for Train Base  6 x 22 Type 1
0 Name: u9448.dat
0 !CATEGORY Magnet
0 !HISTORY 2021-07-20 [MagFors] Original design by Niels Karsdorp
0 !HISTORY 2021-07-20 [MagFors] Added corrected, and missing edge lines
0 // holder
1 16 36 -6 0 0 -1 0 1 0 0 0 0 1 4-4ring13.dat
1 16 36 -6 0 0 -1 0 1 0 0 0 0 1 4-4ring14.dat
1 16 22 -6 0 0 -1 0 13 0 0 0 0 -13 4-4disc.dat
1 16 17 -6 0 0 1 0 15 0 0 0 0 15 4-4disc.dat
1 16 17 -6 0 0 19 0 15 0 0 0 0 15 4-4cylo.dat
1 16 22 -6 0 0 14 0 13 0 0 0 0 13 4-4cylo.dat
0 // plate
1 16 -1.5 0 0 0 0 -7.5 0 4 0 7.5 0 0 2-4cylo.dat
1 16 -1.5 0 0 0 0 -7.5 0 1 0 7.5 0 0 2-4chrd.dat
1 16 -1.5 4 0 0 0 -7.5 0 -1 0 7.5 0 0 2-4chrd.dat
2 24 17 0 -7.5 17 4 -7.5
2 24 17 0 7.5 17 4 7.5
2 24 17 0 7.5 17 0 -7.5
2 24 17 4 7.5 17 4 2
2 24 17 4 -7.5 17 4 -2
1 16 7.75 4 0 9.25 0 0 0 -4 0 0 0 7.5 box3u8p.dat
4 16 0 4 -2 17 4 -2 17 4 -7.5 -1.5 4 -7.5
4 16 17 4 2 0 4 2 -1.5 4 7.5 17 4 7.5
4 16 0 4 -2 -1.5 4 -7.5 -1.5 4 7.5 0 4 2
2 24 17 4 -2 17 8.5 -2
2 24 17 4 2 17 8.5 2
2 24 17 8.5 -2 17 8.5 2
2 24 17 4 2 0 4 2
2 24 17 4 -2 0 4 -2
2 24 0 4 -2 0 4 2
2 24 17 8.5 2 0 4 2
2 24 17 8.5 -2 0 4 -2
4 16 0 4 -2 0 4 2 17 8.5 2 17 8.5 -2
3 16 17 4 2 17 8.5 2 0 4 2
3 16 0 4 -2 17 8.5 -2 17 4 -2
0 // hook
1 16 17 -13 0 0 1 0 4.5 0 0 0 0 4.5 4-4edge.dat
1 16 17 -13 0 0 -12.5 0 4.5 0 0 0 0 4.5 4-4cyli.dat
1 16 0 -8.5 0 4.5 0 0 0 5 0 0 0 4.5 4-4cyli.dat
1 16 0 -3.5 0 -4.5 0 0 0 .5 0 0 0 4.5 4-4cylse.dat
1 16 0 -3 0 -4.5 0 0 -0.5 -1 0 0 0 -4.5 4-4disc.dat
1 16 0 -13 0 0 0 -4.5 0 -4.5 0 4.5 0 0 2-8sphe.dat
1 16 0 -13 0 0 0 4.5 0 -1 4.5 4.5 0 0 2-4edge.dat
1 16 0 -8.5 0 4.5 0 0 0 -4.5 0 0 0 4.5 1-4cyls.dat
1 16 0 -8.5 0 4.5 0 0 0 -4.5 0 0 0 -4.5 1-4cyls.dat
1 16 0 -8.5 0 0 0 -4.5 0 -4.5 0 4.5 0 0 2-4cyli.dat
1 16 4.5 -13 0 0 -4.5 0 4.5 0 0 0 0 4.5 1-4cyls.dat
1 16 4.5 -13 0 0 -4.5 0 4.5 0 0 0 0 -4.5 1-4cyls.dat
1 16 4.5 -13 0 0 -4.5 0 0 0 -4.5 -4.5 0 0 2-4cyli.dat
2 24 17 -16.97186 2 4.5 -16.97186 2
2 24 17 -16.97186 -2 4.5 -16.97186 -2
2 24 5.49785 -17.5 0 4.850836 -17.15755 1.72215
2 24 5.49785 -17.5 0 4.850836 -17.15755 -1.72215
2 24 4.850836 -17.15755 -1.72215 4.5 -16.97186 -2
2 24 4.850836 -17.15755 1.72215 4.5 -16.97186 2
2 24 17 -16.97186 2 17 -22 2
2 24 17 -16.97186 -2 17 -22 -2
2 24 14 -22 2 4.5 -16.97186 2
2 24 14 -22 -2 4.5 -16.97186 -2
1 16 15.5 -22 0 1.5 0 0 0 1 0 0 0 2 rect.dat
4 16 17 -22 2 17 -22 -2 17 -16.97186 -2 17 -16.97186 2
4 16 4.5 -16.97186 2 4.5 -16.97186 -2 14 -22 -2 14 -22 2
4 16 4.5 -16.97186 2 14 -22 2 17 -22 2 17 -16.97186 2
4 16 14 -22 -2 4.5 -16.97186 -2 17 -16.97186 -2 17 -22 -2
    Line 67: 2 24 4.850836 -17.15755 -1.72215 4.5 -16.97186 -2
    Line 68: 2 24 4.850836 -17.15755 1.72215 4.5 -16.97186 2
2021-07-20 06:55:01
Magnet holder for part 290, making s/735s01 obsolete.
Those are in the mail to Admin.
Orion Pobursky [OrionP]
2024-03-23 00:59:39
Update ring primitives via script. This will not reset the vote status of the part.
Steffen [Steffen]
made the following comment.
2024-03-26 14:17:13
I think this is a duplicate of 499.dat
I think that LEGO did not have 2 separate variants of this part in the 1980's
I suggest to replace this by a MOVED-TO that file
Willy Tschager [Holly-Wood]
2025-01-25 16:58:53
* Admittedly I'm not into trains so I try to figure out what we are talking about here. I try to pair them with BL:
https://library.ldraw.org/parts/27031
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x547c
https://library.ldraw.org/parts/9826
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x547b
https://www.bricklink.com/v2/catalog/catalogitem.page?P=x547a
Not in LDraw
My first suggestions would be adding the cylinder length to the title (X.Xmm Cylinder) and add keywords with BL ref to all magnet holders.
Rene Rechthaler [Blechtaler]
2025-01-25 17:09:58
i can confirm 3 variants of the closed ring variant: (i am very much into this kind of trains, i have the parts)
-short cylinder, short magnet
-short cylinder, long magnet
-long cylinder, long magnet
if the plates 2x4 with magnet holders are built into a ring with 5 studs apart, only the first short/short version doesnt connect...
the other two variants connect into a good fitting pair
pic is on DC: https://discord.com/channels/1233675339436396585/1233675825216491520/1263907428731322450
2025-01-25 18:00:26
i think i even have one of the open variants...
there are definitely open and closed variants.
2025-01-25 18:42:27
i guess we need 2 magnets for that...
D10xL6mm and D10xL7mm
the new ones should be the 10x7 like this one: 2959c01.dat
https://library.ldraw.org/parts/3370
there should be a shorter one.
guess i really need to dig the other train parts out...
then we also need two empty magnet holders (long/short), who could share the back connector (its the same)
2025-01-25 19:09:48
2 items:
- Is this variation recognized anywhere else in the community?
- Does the average user care?
2025-01-25 20:11:20
both -> no :(
but I checked the library:
70023.dat is D24xL16
u9044.dat is D26xL15
but they should be D25xL15 (D10xL6mm) and D25xL17,5 (D10x7mm)
there is a chance that both are wrong
2025-01-25 20:29:02
Make a summary, with pictures, and post it to the forums for discussion.
2025-01-25 22:12:12
https://forums.ldraw.org/thread-28633-post-56293.html#pid56293
done
do you also need sizes of the other magnets?
2025-06-09 08:50:05
the rear part should be subfiled, the front cup can get changed in a new variant
I also obsoleted the old magnet, should fit that one: u9044b.dat
https://library.ldraw.org/parts/46116
