Unofficial File parts/u9602.dat
0 ~Electric Train 12V Transformer Type 1 Top
0 Name: u9602.dat
0 !CATEGORY Electric
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\u9602s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\u9602s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\u9602s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\u9602s01.dat
1 16 0 0 60 140 0 0 0 1 0 0 0 70 rect.dat
1 16 70 0 60 0 0 1 0 1 0 -1 0 0 stug-7x7.dat
1 16 -70 0 60 0 0 1 0 1 0 -1 0 0 stug-7x7.dat
1 16 0 88 130 0 0 140 88 0 0 0 -1 0 rect2p.dat
1 16 0 122.641 -130 140 0 0 0 0 -53.359 0 1 0 rect3.dat
0 // Top face (here goes the knob)
1 16 0 34.641 -70 0 0 -140 -34.641 1 0 60 0 0 rect2p.dat
1 16 140 152 -80 0 -5 0 0 0 12 12 0 0 2-4cylo.dat
1 16 140 117 -80 0 -5 0 0 0 -12 12 0 0 2-4cylo.dat
1 16 140 152 -44 0 -5 0 0 0 12 12 0 0 2-4cylo.dat
1 16 140 117 -44 0 -5 0 0 0 -12 12 0 0 2-4cylo.dat
1 16 140 152 -8 0 -5 0 0 0 12 12 0 0 2-4cylo.dat
1 16 140 117 -8 0 -5 0 0 0 -12 12 0 0 2-4cylo.dat
1 16 140 152 -80 0 -1 0 0 0 12 12 0 0 2-4ndis.dat
1 16 140 117 -80 0 -1 0 0 0 -12 12 0 0 2-4ndis.dat
1 16 140 152 -44 0 -1 0 0 0 12 12 0 0 2-4ndis.dat
1 16 140 117 -44 0 -1 0 0 0 -12 12 0 0 2-4ndis.dat
1 16 140 152 -8 0 -1 0 0 0 12 12 0 0 2-4ndis.dat
1 16 140 117 -8 0 -1 0 0 0 -12 12 0 0 2-4ndis.dat
1 16 135 134.5 -62 0 5 0 17.5 0 0 0 0 6 box3u8p.dat
1 16 135 134.5 -26 0 5 0 17.5 0 0 0 0 6 box3u8p.dat
1 16 137.5 134.5 -92 0 0 2.5 17.5 0 0 0 -1 0 rect2p.dat
1 16 137.5 134.5 4 0 0 2.5 17.5 0 0 0 1 0 rect2p.dat
4 16 140 164 -68 140 164 -56 140 152 -56 140 152 -68
4 16 140 117 -68 140 117 -56 140 105 -56 140 105 -68
4 16 140 164 -32 140 164 -20 140 152 -20 140 152 -32
4 16 140 117 -32 140 117 -20 140 105 -20 140 105 -32
4 16 140 173 119 140 176 125 140 176 130 140 0 130
4 16 140 173 119 140 0 130 140 0 -10 140 105 4
4 16 140 173 114 140 173 119 140 105 4 140 117 4
4 16 140 173 109 140 173 114 140 117 4 140 152 4
4 16 140 152 4 140 164 4 140 176 103 140 173 109
4 16 140 176 -103 140 176 103 140 164 4 140 164 -8
3 16 140 176 -103 140 164 -8 140 164 -20
3 16 140 176 -103 140 164 -20 140 164 -32
3 16 140 176 -103 140 164 -32 140 164 -44
3 16 140 176 -103 140 164 -44 140 164 -56
3 16 140 176 -103 140 164 -56 140 164 -68
3 16 140 176 -103 140 164 -68 140 164 -80
4 16 140 173 -109 140 176 -103 140 164 -80 140 164 -92
4 16 140 173 -114 140 173 -109 140 164 -92 140 152 -92
4 16 140 173 -119 140 173 -114 140 152 -92 140 117 -92
4 16 140 176 -125 140 173 -119 140 117 -92 140 105 -92
4 16 140 176 -130 140 176 -125 140 105 -92 140 69.282 -130
4 16 140 69.282 -130 140 105 -92 140 105 -80 140 0 -10
3 16 140 0 -10 140 105 -80 140 105 -68
3 16 140 0 -10 140 105 -68 140 105 -56
3 16 140 0 -10 140 105 -56 140 105 -44
3 16 140 0 -10 140 105 -44 140 105 -32
3 16 140 0 -10 140 105 -32 140 105 -20
3 16 140 0 -10 140 105 -20 140 105 -8
3 16 140 0 -10 140 105 -8 140 105 4
1 16 -140 164.6864 -70 0 1 0 0 0 -11 11 0 0 2-4ndis.dat
4 16 -140 173 -119 -140 176 -125 -140 176 -130 -140 69.282 -130
4 16 -140 0 -10 -140 173 -114 -140 173 -119 -140 69.282 -130
4 16 -140 0 -10 -140 0 130 -140 153.6864 -59 -140 153.6864 -70
4 16 -140 164.6864 -59 -140 153.6864 -59 -140 0 130 -140 173 109
3 16 -140 164.6864 -81 -140 173 -109 -140 153.6864 -81
4 16 -140 173 -114 -140 0 -10 -140 153.6864 -81 -140 173 -109
3 16 -140 153.6864 -81 -140 0 -10 -140 153.6864 -70
4 16 -140 164.6864 -81 -140 176 -81 -140 176 -103 -140 173 -109
4 16 -140 173 109 -140 176 103 -140 176 -59 -140 164.6864 -59
3 16 -140 173 109 -140 0 130 -140 173 114
3 16 -140 173 114 -140 0 130 -140 173 119
4 16 -140 0 130 -140 176 130 -140 176 125 -140 173 119
1 16 -140 164.6864 -70 0 4 0 0 0 -11 11 0 0 2-4cylo.dat
1 16 -138 170.3432 -59 -2 0 0 0 0 5.6568 0 1 0 rect3.dat
1 16 -138 170.3432 -81 -2 0 0 0 0 5.6568 0 -1 0 rect3.dat
0 // Red Dot for the Lamp (hole has 8mm)
1 4 -116 12 -30.784 1 0 0 0 .866 -.5 0 .5 .866 s\u9602s02.dat
Errors Found (HN)
Willy Tschager [Holly-Wood]
Has Uncertified Subfiles
Rene Rechthaler [Blechtaler]
2023-07-08 13:06:46
2023-07-08 13:14:50
made the following comment.
2023-07-08 14:58:24
AFAIK you can't, but if you add this to your stud.dat
1 16 0 -4 0 1 0 0 0 1 0 0 0 1 logo.dat
all parts will be displayed with a stud logo.
And add this:
1 16 0 0 0 0.6 0 0 0 1 0 0 0 0.6 logo.dat
to stud2.dat to have a logo in the hollow studs
And add this:
Gerald Lasser [GeraldLasser]
2023-07-09 15:20:50
you can check the logo:
RIght Click -> View Action -> Stud Logo
Mark Kennedy [mkennedy]
2023-07-12 20:04:48
Might you be able to use a skewed box2-7 primitive for the other side where the studs are?
renamed the part.
2024-01-06 14:45:20
"parts/s/740as01.dat" to "parts/s/u9602.dat"
renamed the part.
2024-01-06 14:45:59
"parts/s/u9602.dat" to "parts/u9602.dat"
posted a vote of Hold
2024-01-06 15:12:22
The origin need to be on the top stud surface.
2024-01-06 17:09:11
only the top or the whole assembly who needs the origin on the top?
2024-01-06 17:37:00
thanks for the renumbering, cleaned it a bit...
2024-01-07 08:48:32
Parts with studs should always have the origin on the top surface.
The bottom has no studs, and is ok.
Steffen [Steffen]
2024-02-11 05:22:43
the red dot is a separate piece of plastic and should become a ~part IMHO
2024-05-29 15:46:11
* No need for a 48er
1 4 -116 -180.866 -31.2846 12.5 0 0 0 .866 -6.25 0 .5 10.825 48\4-4cylc.dat
* Origin is wrong
* Origin is wrong
2024-05-29 15:57:28
should the origin be at the center of the top studs or at the top face, centered on the whole part?
should I do another subfile for the electrics?
2024-05-29 16:23:40
* Good question. I'd say treat the top as it would be a 7 x 14 Plate/Brick.
* As Steffen remarked. The pins of the base have to go into a sub.
2024-05-29 16:25:01
* I don't care about metal rivets in a plastic part. Magnus does, so probably that should subbed as well.
2024-05-29 16:29:54
should that origin then also be the origin of the whole assembly?
2024-05-29 17:06:52
Sure!
2024-09-28 10:11:45
should i include the hole/cutout for the cable?
2024-10-01 16:09:36
fixed the origin
2025-08-26 06:40:10
* Rects (FMEO)
2026-06-02 12:22:08
* as it looks now this is a sub.
2026-06-02 16:41:12
the red button is a separate part -> keep it as subpart or one more part?
(how can i check that in LDPE?)
