Unofficial File parts/s/6377s01.dat
~Duplo Train Track Straight  4 x  8 - Half
0 ~Duplo Train Track Straight  4 x  8 - Half
0 Name: s\6377s01.dat
0 !HISTORY 2013-01-10 [MMR1988] BFC'ed, add license, replace of quads by boxes and rects, rewrite some ares
0 !HISTORY 2024-11-22 [WUIt] Used subfile for tracks, moved origin to point of symmetry, and merged symmetric elements across the split
0 !HISTORY 2025-02-14 [WUIt] Rearranged to more subparts, corrected underside, and removed several T-junctions around middle sleeper
0 // front sleeper
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s04.dat
0 // right track base
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s02.dat
0 // right track ribs
1 16 53 6.5 0 1 0 0 0 1 0 0 0 1 s\35965s01.dat
0 // big sleeper front wall
4 16 -64 12 -40 -68 12 -40 -80 24 -40 -41 19 -40
4 16 -41 19 -40 -80 24 -40 80 24 -40 41 19 -40
4 16 80 24 -40 68 12 -40 64 12 -40 41 19 -40
0 // big sleeper helm
4 16 80 24 -40 -80 24 -40 -76 24 -36 76 24 -36
4 16 76 24 36 80 24 40 80 24 -40 76 24 -36
2 24 -80 24 -40 80 24 -40
0 // big sleeper boot
1 16 74 16 0 0 0 6 0 -8 0 40 0 0 box2-5.dat
4 16 68 8 -40 68 12 -40 80 24 -40 80 8 -40
4 16 80 24 40 68 12 40 68 8 40 80 8 40
0 // front sleeper rear wall
4 16 34 2 -120 -34 2 -120 -34 0 -120 34 0 -120
4 16 -37 8 -120 -34 2 -120 34 2 -120 37 8 -120
4 16 -37 19 -120 -37 8 -120 37 8 -120 37 19 -120
4 16 80 24 -120 68 12 -120 68 8 -120 80 8 -120
4 16 -68 8 -120 -68 12 -120 -80 24 -120 -80 8 -120
4 16 -80 24 -120 -68 12 -120 -64 12 -120 -41 19 -120
4 16 80 24 -120 -80 24 -120 -41 19 -120 41 19 -120
4 16 64 12 -120 68 12 -120 80 24 -120 41 19 -120
0 // left track side
1 16 66 10 80 0 2 0 0 0 2 40 0 0 box2-7.dat
0 // right track side
4 16 68 7 -160 68 8 -120 68 8 120 68 7 160
1 16 66 10 -80 0 2 0 0 0 2 40 0 0 box2-7.dat
0 // front sleeper helm, front, boot, and back
4 16 -32 24 -160 -80 24 -160 -76 24 -156 -36 24 -156
4 16 -80 24 -160 -80 24 -120 -76 24 -124 -76 24 -156
3 16 -80 24 -120 38 24 -124 -76 24 -124
4 16 -80 24 -120 80 24 -120 42 24 -124 38 24 -124
3 16 76 24 -124 42 24 -124 80 24 -120
4 16 80 24 -160 76 24 -156 76 24 -124 80 24 -120
3 16 80 24 -160 42 24 -156 76 24 -156
4 16 38 24 -156 42 24 -156 80 24 -160 -8 24 -160
2 24 -80 24 -120 80 24 -120
2 24 80 24 -160 -8 24 -160
2 24 -80 24 -160 -32 24 -160
2 24 -34 0 -120 34 0 -120
1 16 74 16 -140 0 0 6 0 -8 0 -20 0 0 box2-5.dat
1 16 -74 16 -140 0 0 -6 0 -8 0 -20 0 0 box2-5.dat
4 16 -68 8 -160 -80 8 -160 -80 24 -160 -32 24 -160
4 16 -40 7 -160 -68 7 -160 -68 8 -160 -32 24 -160
4 16 28 24 -160 80 24 -160 80 8 -160 68 8 -160
4 16 28 24 -160 68 8 -160 68 7 -160 40 7 -160
3 16 -68 8 -160 -68 7 -160 -68 8 -120
3 16 68 8 -120 68 7 -160 68 8 -160
Not releaseable Awaiting Admin Review (CCF) Awaiting Admin Review (CCF)
Certify
Willy Tschager [Holly-Wood]
Certify
Peter Blomberg [WUIt]
2024-11-22 08:20:49
Reusing subpart 35965s01 for track ribs. Merged symmetric elements across the split (reduces total number of quads).
Moved the origin of subpart 6277s01 to point of symmetry. Subpart 6377s01 has only one parent and it is updated accordingly.
Included !HISTORY comments regarding changes.
6391 Notes: kept bottom reinforcements (newer part has cylinders), kept bottom shape and thicknesses (newer part has more curved corners, thicker plate, and deeper reinforcements).
6377 Notes: didn't correct bottom edge reinforcements, didn't add wells near bottom vertical walls, and didn't correct step within the underside boxes as these may have been added in later production batches of the part.
Rene Rechthaler [Blechtaler]
made the following comment.
2024-11-22 11:02:03
looks like it can still be reused for 31442
posted a vote of Hold
2025-03-13 13:21:57
At least one edgeline missing
2025-03-14 12:15:01
Rearranged and subfiled lines to create more reusable modules. Corrected underside edge reinforcement. Removed several T-junctions around the exterior of the middle and end sleepers. Subfile 6377s01 is reused by 31442. Subfiles 6377s02 and 6377s03 are reused by 31442, 35965, and 5370. Subfile 6377s04 is reused by 35965 and could be reused elsewhere (e.g. track crossings).
edited the part header.
2025-04-30 20:49:58
Header Edits
description:
~Duplo Train Track Straight 4 x 8 (Half)
to
Comment:
Changed parenthesis to dash in description
posted a vote of Certify
2025-08-16 17:03:43
2025-08-16 19:39:38
2025-09-15 07:31:49
* Looks good
2025-09-18 10:16:44
Minor update to fix overlap between s02 and s03.
Converted some rects to boxes.
2025-09-20 06:42:46
2025-09-20 10:19:33
