0 Tyre 10/100 x 17 Offset Tread
0 Name: 3634.dat
0 Author: Leonardo Zide [leozide]
0 !CATEGORY Tyre
0 !KEYWORDS 17 x 43, 43.2, Brickowl 706229
0 !HISTORY 1998-12-15 [PTadmin] Official Update 1998-10
0 !HISTORY 2007-06-29 [PTadmin] Header formatted for Contributor Agreement
0 !HISTORY 2010-03-31 [Philo] BFCed, 48ed
0 !HISTORY 2025-02-28 [Blechtaler] complete rework with subfile
0 !HISTORY 2026-01-20 [MagFors] Update description
0 // Nomenclature: width_(mm)/profile_as_%age_of_width x rim_diameter_(mm)
0 // inside teeth
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3634s03.dat
1 16 0 0 0 0.7071 0.7071 0 -0.7071 0.7071 0 0 0 1 s\3634s03.dat
1 16 0 0 0 0 1 0 -1 0 0 0 0 1 s\3634s03.dat
1 16 0 0 0 -0.7071 0.7071 0 -0.7071 -0.7071 0 0 0 1 s\3634s03.dat
1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\3634s03.dat
1 16 0 0 0 -0.7071 -0.7071 0 0.7071 -0.7071 0 0 0 1 s\3634s03.dat
1 16 0 0 0 0 -1 0 1 0 0 0 0 1 s\3634s03.dat
1 16 0 0 0 0.7071 -0.7071 0 0.7071 0.7071 0 0 0 1 s\3634s03.dat
0 // Outside Teeth
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3634s01.dat
1 16 0 0 0 0 -1 0 -1 0 0 0 0 1 s\3634s01.dat
1 16 0 0 0 0 -1 0 1 0 0 0 0 1 s\3634s01.dat
1 16 0 0 0 1 0 0 0 -1 0 0 0 1 s\3634s01.dat
1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\3634s01.dat
1 16 0 0 0 0 1 0 1 0 0 0 0 1 s\3634s01.dat
1 16 0 0 0 0 1 0 -1 0 0 0 0 1 s\3634s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\3634s01.dat
0 // front slope
1 16 0 0 -10.6 2 0 0 0 0 2 0 1.6 0 4-4con11.dat
1 16 0 0 -17 8 0 0 0 0 8 0 6.4 0 4-4con3.dat
1 16 0 0 -17 32 0 0 0 0 32 0 1 0 4-4edge.dat
0 // inside
1 16 0 0 -9 22 0 0 0 0 22 0 18 0 4-4cylo.dat
1 16 0 0 9 2 0 0 0 0 2 0 -1 0 4-4ring11.dat
1 16 0 0 9 24 0 0 0 0 24 0 -15.8 0 4-4cylo.dat
1 16 0 0 -11.6 6 0 0 0 0 6 0 4.8 0 4-4con4.dat
1 16 0 0 -14 3 0 0 0 0 3 0 2.4 0 4-4con10.dat
1 16 0 0 -14 33 0 0 0 0 33 0 1 0 4-4edge.dat
1 16 0 0 -14 2.75 0 0 0 0 2.75 0 -1 0 4-4ring12.dat
1 16 0 0 -14 3.25 0 0 0 0 3.25 0 -1 0 4-4ring11.dat
1 16 0 0 -14 39 0 0 0 0 39 0 23 0 4-4cylo.dat
inside is now standard res like the rim family
why are the old subfiles named 3634a/b/c? (a could be a prim, b and c are now unused)
This is before my time, but I guess the subfile suffix, -sXX was not mandatory from the beginning.
It possible, find a way to make those subfiles obsolete/unused. They are confusing.
keywords:
17 x 43
to
43.2
added diameter
s01 could also be used in 574.dat (the old one for the red 9T gear) with slight rework/split
keywords:
43.2
to
43.2, 17 x 43
description:
Tyre 10/130 x 17 Offset Tread
to
history:
to
made the rear inside standard res and improved the cones
