Unofficial File parts/s/5370s01.dat
~Duplo Train Track Straight with  2 x  8 Plates on Both Sides - Half
0 ~Duplo Train Track Straight with 2 x 8 Plates on Both Sides - Half 0 Name: s\5370s01.dat 0 Author: Peter Blomberg [WUIt] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // based on part 35965 0 // front sleeper 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s04.dat 0 // right track base 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s02.dat 0 // right track ribs 1 16 53 6.5 0 1 0 0 0 1 0 0 0 1 s\35965s01.dat 0 // front sleeper front wall 4 16 -40 7 -160 -68 7 -160 -68 8 -160 -32 24 -160 4 16 28 24 -160 68 8 -160 68 7 -160 40 7 -160 0 // front sleeper rear wall 4 16 34 2 -120 -34 2 -120 -34 0 -120 34 0 -120 4 16 -37 8 -120 -34 2 -120 34 2 -120 37 8 -120 4 16 -37 19 -120 -37 8 -120 37 8 -120 37 19 -120 4 16 64 12 -120 80 12 -120 80 24 -120 41 19 -120 4 16 -80 12 -120 -64 12 -120 -41 19 -120 -80 24 -120 4 16 -41 19 -120 41 19 -120 80 24 -120 -80 24 -120 2 24 -34 0 -120 34 0 -120 0 // top surfaces 1 16 94 8 0 0 0 26 0 1 0 160 0 0 rect.dat 1 16 160 12 0 0 0 40 0 -12 0 160 0 0 box2-5.dat 4 16 120 0 -160 120 0 160 120 8 160 120 8 -160 2 24 120 0 160 120 8 160 2 24 120 0 -160 120 8 -160 4 16 68 7 -160 68 8 -160 68 8 160 68 7 160 0 // bottom spacer surface 1 16 100 12 0 0 0 20 0 -1 0 156 0 0 rect3.dat 1 16 72 12 -80 0 0 -8 0 -1 0 40 0 0 rect3.dat 1 16 72 12 80 0 0 -8 0 -1 0 40 0 0 rect3.dat 1 16 120 18 0 0 1 0 0 0 6 156 0 0 rect3.dat 0 // bottom helm of track end 4 16 -80 24 -156 -80 24 -120 -76 24 -124 -76 24 -156 3 16 -80 24 -120 38 24 -124 -76 24 -124 4 16 -80 24 -120 80 24 -120 42 24 -124 38 24 -124 3 16 76 24 -124 42 24 -124 80 24 -120 4 16 80 24 -156 76 24 -156 76 24 -124 80 24 -120 2 24 -80 24 -120 80 24 -120 2 24 200 24 -160 -8 24 -160 2 24 160 24 -156 80 24 -156 0 // bottom helm of track middle 4 16 76 24 -36 80 24 -40 -80 24 -40 -76 24 -36 4 16 76 24 36 80 24 40 80 24 -40 76 24 -36 0 // bottom helm of plate 4 16 200 24 160 200 24 -160 196 24 -156 196 24 156 4 16 200 24 -160 -8 24 -160 38 24 -156 196 24 -156 4 16 120 24 -156 120 24 156 124 24 156 124 24 -156 3 16 32 24 160 76 24 156 36 24 156 4 16 76 24 156 32 24 160 200 24 160 196 24 156 0 // front surfaces 4 16 28 24 -160 200 24 -160 120 8 -160 68 8 -160 4 16 200 0 -160 120 0 -160 120 8 -160 200 24 -160 1 16 80 18 -138 0 -1 0 0 0 6 18 0 0 rect.dat 4 16 80 24 -156 80 12 -156 160 12 -156 160 24 -156 0 // back surfaces 4 16 32 24 160 68 8 160 120 8 160 200 24 160 4 16 200 0 160 200 24 160 120 8 160 120 0 160 4 16 160 24 156 160 12 156 80 12 156 80 24 156 1 16 80 18 138 0 -1 0 0 0 6 18 0 0 rect.dat 0 // track middle box outer vertical 1 16 80 18 0 0 -1 0 0 0 6 40 0 0 rect.dat 4 16 80 24 -40 80 12 -40 64 12 -40 41 19 -40 4 16 -80 12 -40 -80 24 -40 -41 19 -40 -64 12 -40 4 16 -41 19 -40 -80 24 -40 80 24 -40 41 19 -40 2 24 -80 24 -40 80 24 -40 0 // inside box of plate 0 BFC INVERTNEXT 1 16 160 24 0 0 0 36 0 -20 0 156 0 0 box5.dat 0 // notches on plate 1 16 126 4 140 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 100 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 60 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 20 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 -20 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 -60 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 -100 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 126 4 -140 0 0 2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 140 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 100 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 60 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 20 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 -20 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 -60 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 -100 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 194 4 -140 0 0 -2 0 19 0 1.5 0 0 box4-1.dat 1 16 180 4 -154 -1.5 0 0 0 19 0 0 0 2 box4-1.dat 1 16 180 4 154 1.5 0 0 0 19 0 0 0 -2 box4-1.dat 1 16 140 4 -154 -1.5 0 0 0 19 0 0 0 2 box4-1.dat 1 16 140 4 154 1.5 0 0 0 19 0 0 0 -2 box4-1.dat 0 // underside studs on plate 1 16 160 4 120 0 0 1 0 -5 0 1 0 0 stud8.dat 1 16 160 4 80 0 0 1 0 -5 0 1 0 0 stud8.dat 1 16 160 4 40 0 0 1 0 -5 0 1 0 0 stud8.dat 1 16 160 4 0 0 0 1 0 -5 0 1 0 0 stud8.dat 1 16 160 4 -40 0 0 1 0 -5 0 1 0 0 stud8.dat 1 16 160 4 -80 0 0 1 0 -5 0 1 0 0 stud8.dat 1 16 160 4 -120 0 0 1 0 -5 0 1 0 0 stud8.dat 2 24 32 24 160 200 24 160 2 24 80 24 156 120 24 156
User Vote
RainbowDolphin Certify
2025-03-14 12:18:00
Created to use the new modular subfiles in 6377 and 35965.
edited the part header.
2025-04-30 20:45:08
Header Edits
description:
~Duplo Train Track Straight with 2 x 8 Plates on Both Sides (Half)
to
Comment:
Changed parenthesis to dash in description
posted a vote of Certify
2025-08-16 17:05:28
This part is copyright © Peter Blomberg
