Unofficial File parts/3626bpss.dat
Part Attributes: Base Part: 3626b.dat
Minifig Head with SW Moustache, Eyebrows and Small Eyelashes Pattern (Blocked Hollow Stud)
0 Minifig Head with SW Moustache, Eyebrows and Small Eyelashes Pattern (Blocked Hollow Stud) 0 Name: 3626bpss.dat 0 Author: Jeff Jones [notmaster] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 3626pb0214, Cloud City, Lando Calrissian 0 !KEYWORDS Rebrickable 3626bpr0454, set 10123, Set 6210, Set 7754, Star Wars
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\3626cpsks01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626cpsks01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626bs02.dat 1 16 0 4 0 0 0 -8 0 -6.4 0 -8 0 0 t04o6250.dat 1 16 0 4 0 8 0 0 0 -6.4 0 0 0 -8 t04o6250.dat 1 16 0 17 0 0 0 8 0 6.4 0 -8 0 0 t04o6250.dat 1 16 0 17 0 -8 0 0 0 6.4 0 0 0 -8 t04o6250.dat 1 16 0 4 0 0 0 8 0 -6.4 0 8 0 0 t04o6250.dat 1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 8 t04o6250.dat 1 16 0 17 0 0 0 -8 0 6.4 0 8 0 0 t04o6250.dat 1 16 0 17 0 8 0 0 0 6.4 0 0 0 8 t04o6250.dat 1 16 0 17 0 13 0 0 0 -13 0 0 0 13 2-4cyli.dat 1 16 0 4 0 13 0 0 0 13 0 0 0 -13 1-8cyli.dat 1 16 0 4 0 -13 0 0 0 13 0 0 0 -13 1-8cyli.dat
Not releaseable Errors Found (HHN) Errors Found (HHN)
  • Ensure correct Minifig category
User Vote
notmaster Hold
KnightOfTarenta Hold
Part Author
2025-04-12 13:10:31
posted a vote of Hold.
2025-06-06 07:01:11
https://library.ldraw.org/parts/45368 and https://library.ldraw.org/parts/42670 are currently both problematic.
Reason: Stud type changes are typically not regarded and this is the only difference between the two (unless there is a larger difference caused by the re-issue, but than this should be reflected in the part as well, which is curently not the case).
If no difference can be identified and only one version is kept, I would prefer the "b" type version, since this was the first appearance and also the more common one.
Part Author
made the following comment.
2025-06-06 08:44:06
before anything happens we should probably ask ejb about this
2025-07-19 05:18:47
If you are referring to the asymmetry in that picture, that's rubbed off paint.
Part Author
2025-08-28 07:46:10
bump
This part is copyright © Jeff Jones
LDraw.org Parts Tracker,
