Unofficial File parts/70943p01.dat
Figure Leg Mecha  2 x  4 x  6.333 Left with Black Friction Pin Pattern
0 Figure Leg Mecha  2 x  4 x  6.333 Left with Black Friction Pin Pattern
0 Name: 70943p01.dat
0 !CATEGORY Figure
0 !KEYWORDS Bricklink 70943, Brickowl 8618, Brickset 70943, Rebrickable 70943c01
0 !KEYWORDS Set 71804, Set 75332
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\70943s01.dat
1 16 40 -50 10 0 -1 0 1 0 0 0 0 1 studa.dat
1 16 40 -70 10 0 -1 0 1 0 0 0 0 1 studa.dat
1 16 40 -70 30 0 -1 0 1 0 0 0 0 1 studa.dat
1 16 40 -50 30 0 -1 0 1 0 0 0 0 1 studa.dat
1 16 32 -130 -10 0 -1 0 1 0 0 0 0 1 stud2a.dat
1 16 32 -110 -10 0 -1 0 1 0 0 0 0 1 stud2.dat
1 16 32 -130 10 0 -1 0 1 0 0 0 0 1 stud2a.dat
1 16 32 -110 10 0 -1 0 1 0 0 0 0 1 stud2a.dat
1 0 0 -118 0 0 0 1 0 1 0 -1 0 0 s\70943s02.dat
Gerald Lasser [GeraldLasser]
2026-03-06 19:14:47
2026-03-06 19:17:00
Jeff Jones [notmaster]
made the following comment.
2026-03-07 09:00:07
Should be shortcut
2026-03-07 09:26:41
This is a dual mould, right?
It's not possible to remove the pin. Then the file structure is good.
2026-03-07 09:36:16
I saw that pin show up plenty of times
Also wonder if you could do that rancor using that model (or just the hands) which also needs a new part for the arm socket which showed up in galidor
Rene Rechthaler [Blechtaler]
2026-03-07 14:26:04
its strange that only one of the hollow top studs has the stud logo
(should be either all or none)
2026-03-07 16:05:48
stud2a does not induce a logo
2026-03-07 16:06:59
@magnus, I really don'T know if the pins is liserted or molded in. I have only two of them and I don't want to destroy them...
2026-03-07 16:08:39
yes but the one stud 2 has one, the 3 stud2a not -> 4x stud2a and more edge prims?
