Unofficial File parts/32004a.dat
Wheel Rim 18 x 41 Model Team Type  1
0 Wheel Rim 18 x 41 Model Team Type 1 0 Name: 32004a.dat 0 Author: Gerald Lasser [GeraldLasser] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS 68.8 x 24S, Black Cat, Giant Truck, Set 5571
0 // Nomenclature: width_(mm) x rim_diameter_(mm) [optional qualifier] 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32004s01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32004as01.dat 1 16 0 0 0 .5 .866025 0 -.866025 .5 0 0 0 1 s\32004as01.dat 1 16 0 0 0 -.5 .866025 0 -.866025 -.5 0 0 0 1 s\32004as01.dat 1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\32004as01.dat 1 16 0 0 0 -.5 -.866025 0 .866025 -.5 0 0 0 1 s\32004as01.dat 1 16 0 0 0 .5 -.866025 0 .866025 .5 0 0 0 1 s\32004as01.dat
    Line 16: 1 16 0 0 0 .5 .866025 0 -.866025 .5 0 0 0 1 s\32004as01.dat
    Line 17: 1 16 0 0 0 -.5 .866025 0 -.866025 -.5 0 0 0 1 s\32004as01.dat
    Line 19: 1 16 0 0 0 -.5 -.866025 0 .866025 -.5 0 0 0 1 s\32004as01.dat
    Line 20: 1 16 0 0 0 .5 -.866025 0 .866025 .5 0 0 0 1 s\32004as01.dat
None
2021-03-15 21:30:02
2021-03-15 21:45:01
extended desctiption
Peter Blomberg [WUIt]
made the following comment.
2025-10-18 19:13:15
The rim keyword is not needed since it is already part of the description
edited the part header.
2025-10-18 19:22:24
Header Edits
help:
0 !HELP
to
0 !HELP
keywords:
68.8 x 24S, rim
to
68.8 x 24S, Set 5571, Giant Truck, Black Cat
Comment:
removed unneeded "rim" KW, added set no. + name, since it was exclusive to that.
LDraw.org Parts Tracker,
