Unofficial File parts/833.dat
Electric Switch: Remote Control for Train Point  2 x  7 (Complete)
0 Electric Switch: Remote Control for Train Point 2 x 7 (Complete) 0 Name: 833.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP place 3068ap01.dat and 3068ap02.dat 0 !HELP 1 15 0 -8 0 1 0 0 0 1 0 0 0 1 3068ap01.dat 0 !HELP place electrical plugs like 567c01.dat or 567c04.dat 0 !HELP 1 1 20 10 -10 0 0 1 0 -1 0 1 0 0 567c01.dat 0 !HELP place switch plugs like u9608c01.dat or u9608c02.dat 0 !HELP 1 1 0 19 20 -1 0 0 0 -1 0 0 0 1 u9608c01.dat 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 7852, Rebrickable 7852, Set 753, Set 754, Train 0 !CMDLINE -c1 0 !HISTORY 2024-02-15 [Steffen] separated into ~parts 0 !HISTORY 2024-11-11 [Blechtaler] moved origin to top, separated electric contacts
1 16 0 32 -50 1 0 0 0 1 0 0 0 1 u9256.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 u9257.dat 1 4 0 0 -60 1 0 0 0 1 0 0 0 1 u9258.dat 1 494 0 0 0 1 0 0 0 1 0 0 0 1 u9259.dat
None
2023-09-13 10:16:49
very coarse part (I dont have that part, made it from online pics)
if someone has that part, respond if dimensions are wrong...
2023-09-15 10:02:20
better description and help
Steffen [Steffen]
posted a vote of Hold.
2024-02-11 04:49:38
wrong type, this is a shortcut, not a part.
we need 3 ~parts which comprise this: the top, the bottom and the red switch
made the following comment.
2024-02-11 10:32:00
I know that, but I dont have that part (does anyone else?)
I am not even sure about the number/name...
Steffen [Steffen]
2024-02-15 18:28:08
split file into ~parts
Steffen [Steffen]
2024-02-15 18:28:28
corrected title
Steffen [Steffen]
2024-02-15 18:36:12
btw I have this part :) hurray
thanks for modeling it
I will come back and check its dimensions etc once I got hold of it from the attic
2024-02-15 20:47:16
thanks for the split...
If you are searching for your part, do you also have the corresponding triple plug? (this one also should be checked)
2024-11-11 21:32:02
moved origin to top, separated contacts
2024-11-11 21:32:48
got better pictures and dimensions
Willy Tschager [Holly-Wood]
2025-09-15 07:04:42
* There is a slit around the switch.
LDraw.org Parts Tracker, Steffen,
