Unofficial File parts/6377.dat
Duplo Train Track Straight  4 x  8
0 Duplo Train Track Straight  4 x  8
0 Name: 6377.dat
0 !CATEGORY Train
0 !HISTORY 2013-01-10 [MMR1988] BFC'ed, set license, header cosmetic
0 !HISTORY 2024-11-22 [WUIt] Moved origin of subpart to point of symmetry and merged symmetric elements across the split
0 !HISTORY 2025-02-14 [WUIt] Rearranged to more subparts, corrected underside, and removed several T-junctions around middle sleeper
0 // big sleeper
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s03.dat
0 // halves
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\6377s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\6377s01.dat
Not releaseable Needs 1 More Vote (CF) Needs 1 More Vote (CF)
Certify
Peter Blomberg [WUIt]
2024-11-22 08:20:49
Reusing subpart 35965s01 for track ribs. Merged symmetric elements across the split (reduces total number of quads).
Moved the origin of subpart 6277s01 to point of symmetry. Subpart 6377s01 has only one parent and it is updated accordingly.
Included !HISTORY comments regarding changes.
6391 Notes: kept bottom reinforcements (newer part has cylinders), kept bottom shape and thicknesses (newer part has more curved corners, thicker plate, and deeper reinforcements).
6377 Notes: didn't correct bottom edge reinforcements, didn't add wells near bottom vertical walls, and didn't correct step within the underside boxes as these may have been added in later production batches of the part.
2025-03-14 12:15:01
Rearranged and subfiled lines to create more reusable modules. Corrected underside edge reinforcement. Removed several T-junctions around the exterior of the middle and end sleepers. Subfile 6377s01 is reused by 31442. Subfiles 6377s02 and 6377s03 are reused by 31442, 35965, and 5370. Subfile 6377s04 is reused by 35965 and could be reused elsewhere (e.g. track crossings).
posted a vote of Certify
2025-08-16 17:03:26
